There is an auxiliary switch in the door lock and switch assembly that
is activated at the end of the wash cycle for the machine to advance to the spin cycle.
This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies
that the auxiliary switch cannot be activated and the door lock and
switch assembly is faulty. Replaced the door lock and switch assembly
(part #131763202) to address the issue.
Disconnect power to the
machine. Open the washer door then look for the retaining hoop securing
the door seal around the lip of the door opening. Stretch the retainer
spring of the door seal retaining hoop then remove it.
Carefully
peel off part of the door seal from the lip of the door opening near the
door lock and switch assembly. Remove enough of the door seal to gain
access to the door lock and switch assemblyI have a frigidaire affinity front loader washer - 3e820a8.jpg src="/uploads/images/3e820a8.jpg" alt="3e820a8.jpg" class="h_mi" />
Remove the screws
securing the door lock and switch assembly to the front panel. Once the
screws are removed, lift the door lock and switcI have a frigidaire affinity front loader washer - 1a4b866.jpgthen pull it
away from the front panel.
Take the door lock and switch assembly
out of the macI have a frigidaire affinity front loader washer - febd08e.jpgnnect the electrical connections then
connect it to the new door lock and switch assembly.
Put the new
door lock and switch assembly back into position in the front panel and
secure it with the securing screws.
Properly put the eased part
of the door seal back over the lip of the door opening then secure it
with the retaining hoop.
Hey friend, thanks for your post!
I see that your Frigidaire washer will not spin on the final cycle. You could be having an issue with your motor or control panel. It is possible that the control panel is not sending the required information to your motor in order to process the spin cycle. Or it could be that the motor is not receiving the signal from your control panel to spin.
I would recommend performing a reset on your appliance which you can do by unplugging the power cord or flipping the circuit breaker for ten minutes. I hope this information is helpful. -Matt
Frigidaire affinity frontload washer how long does the cleaning cycle run for
How long is the clean cycle for Frigidaire affinity frontload washer
Basket spins while washing should only spin on spin cycle
