I have 4 usb ports 1.0 I am not able to download my camera as i am told I NEED 2.0 PORTS. i purchased a 2.0 hub with 4 usb ports. it still did not work. help. ( gateway 2001 operating sys XP)
The port in the PC needs to be USB 2.0 standard.
A quick analogy. Think of a tap with 1/2" outlet, and you connect an adapter and a 1" hose to it. It will work, but you will not get more water just because you attached a thicker hose; the original outlet has to have higher diameter to give you more water.
If all your USB ports are 1.0 version, the only option is to purchase an USB 2.0 PCI card mounted inside the computer - this will give you 2 or 4 (depending on card model) USB 2.0 outlets.
Please come back with a rating/testimonial if helped.
