Question about RIM Cell Phones
My blackberry 9700 has stopped making sound. When on speakerphone, i cannot hear the other person speaking, i cannot hear any ringers, or videos on youtube, no audio clips at all. i have tried to go through everything in the settings to try to solve this problem but nothing seems to work, and my vibration just stopped working as well. What do i do !
    Top Expert:
  • RIM Master
  • 30,787 Answers
Take it out of aeroplane mode maybe.
Posted on Oct 10, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: My blackberry bold speaker power loss
open the back cover, there is a white soft thing under the flash cover. push it a little bit with a tooth pick or a sharp knife, it should increase the volume dramatically.
Posted on Jul 01, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: My Blackberry Bold 9700 has issues buffering
I can't speak to the speakerphone static issue per se, but for the video issue, and for almost all erratic behavior issues, I have to recommend updating / replacing the firmware of electronic devices. The latest BlackBerry Bold 9700 system software is available through here.
Posted on Mar 22, 2010
waaib
SOURCE: blackberry bold 9000 speakerphone doesn't work!
webburst has it right. I have same issue. if I squeeze the phone at the top the speakerphone works great. plastic spacer or webbursts solution above will works great.
Posted on Aug 21, 2010
SOURCE: ringer is marked as off
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Posted on Feb 08, 2011
When i make a call my bold doesnt even give me a speakerphone option, it gives me headset instead, what do i do?
Try clicking on the Speakerphone button ($) while on call and see if it's going to enable your speakerphone capability
Apr 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
My blackberry bold 9700 just stopped ringing in the middle of a call. It will vibrate & play the sound on videos but even though the volume & everything is turned up - it still won't make any...
have you tried removing the battery for one full minute?... try it if still doesnt work try a master reset...you will have to back up phone first
Sep 30, 2010 | RIM BlackBerry Bold 9700 Smartphone
Speaker for Speakerphone Broken? Where/How to fix?
It is clear that your speakerphone (which we call ringer) is not functioning, there it's not a big problem, you can fix it if you know how to open these kinds of gadgets, but i don't recommend, just go to a mobile repairing shop and tell them the problem, they fix it by replacing the ringer for you. They will charge you for the new ringer and for servicing, but be careful since there're many technicians who just want to charge very high amount without much condition but telling this and that.. so I recommend you to visit the shop you know before or your friend knows.. Good luck.
May 04, 2010 | HTC Touch P3450 Smartphone
How do you turn the loudspeaker on --bold 9700
when making a call, press the menu button you will see an option "activate speakerphone".
Feb 27, 2010 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry Bold 9700 has issues buffering Youtube videos. Also, my speakerphone has a lot of static. Any suggestions?
Jan 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
Callers can only hear me on speakerphone
first try to formate the set ...and problem is still there then its hardware problem ....you hv to change your phone's Mic
Jul 17, 2009 | RIM BlackBerry Pearl 8100
Jun 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry sound not working
Same problem here with a BlackBerry 8830. Elsewhere found a solution for another model that worked for mine:
1) Plug in headset.
2) Turn off BB.
3) Remove phone battery.
4) Reinstall battery and let phone restart.
5) Remove headset.
Nov 29, 2008 | Cell Phones
Cell Phones Logo
102 people viewed this question
Top RIM Cell Phones Experts
RONALD CARTER JR
Ekse
William Norris
William Norris
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
