SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Casios have 2 time modes.The 12 hour mode (am,pm) and the so called "military time" 24 hour mode.When your set time,date,year there is an option 12H or 24H.Choose the 12H by pressing the lower right button when in setting procedure,I say again.Press tthe upper left "ADJUST" button to finish the procedure.
When you are looking at the watch you have 2 buttons on the left side, top button being A and bottom button being C. ON the right the top button in B and the bottom one is D. If you press and hold the A button in time keeping mode the numbers will start to flash. While things are flashing, hit the D button and it should switch between 24 and 12 hour times, then hit A again to escape the time setting mode
On the Casio 2747 you can easily change between 12-hour and 24-hour (i.e. Military time)... Follow these steps:
1. Make sure you are in Timekeeping Mode (i.e. digital display shows date at the bottom). 2. Press the "D" button (i.e. bottom-right button) to toggle between 12-hour and 24-hour timekeeping.
Note: 12-hour timekeeping mode will display an "A" or "P" for AM and PM.
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
