I want to answer your question but I would need so many other questions answered. Topping of my list of necessary things to understand about your situation would be to understand why you would want to spend any time or money on this system? Are you going to actually use it after the ram upgrade? If so your money would go a lot further getting a used 2010 computer which would still be obsolete but may come with the 2gb ram right right from the factory. Maybe you should hit your local Craigslist and grab a $20 computer or take one a friend is sending to be recycled?
SOURCE: Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
SOURCE: Processor Upgrade and Memory query
This motherboard supports up to 3gig of RAM so you can go ahead and upgrade it, There's no particular order fo install the RAm just put it to the empty slot then that's ok..
Hope that helps.........
SOURCE: Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
SOURCE: intel 82845G/GL motherboard
One or both of the new RAM modules is incompatible, defective or not inserted properly. Try one at a time also verify your board supports 1GB and the type of RAM you are using.
SOURCE: Computer Information
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16): http://www.intel.com/design/chipsets/datashts/307502.htm
YBC (/)
