Logitech Webcam Logo
Posted on Jul 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I call someone or someone calls me, my voice sounds like the chipmunks. I have to hang up and call again to correct the problem. I have a pro 9000.
Johan vL
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 24, 2019
Johan vL
Contributor
Level 1:
Answers
Questions
0
Helped
247
Points
* Right click on the speaker icon (bottom right of taskbar)
* Click on recording devices
* Select the webcam microphone
* Click Properties then select the Advanced tab
* Under "Default Format" select something other than the default option (which is probably 48k Hz).
* Click Apply
* Then go back to the 48k Hz and click Apply.
micky dee
Level 3:
  • Logitech Master 3,015 Answers
  • Posted on Jul 12, 2010
micky dee
Logitech Master
Level 3:
Answers
3015
Questions
0
Helped
1060310
Points
8762
1) make sure your mic is set as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
2) Check you have DirectX 9 or later installed to support your cam
3) You may have to re-install the software - browse the photo gallery and click on your model - check out any known problems as well
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
1helpful
Sound problem chipmunk voices on my acer aspire one. All of a sudden, every voice on my acer aspire laptop sounds like a chipmunk, or as though the news anchors have inhaled helium. How do I fix it??
Realtek sound has an "Audio Manager" control panel thing of sorts that can be opened by right-clicking a tray icon or using a shortcut in the control panel. The audio manager features a "pitch" setting that can get changed accidentally. All you need is to located that setting and return it to zero. Young children have a talent for finding this setting and changing it without letting the adults know that they have done so! Sound familiar perchance?
tip
How to Fix Issue When All Sounds from Computer Sound Like Chipmunks
Chipmunk Sounds From Computer Speakers
My wife had an interesting issue over the weekend. Anything she played on her computer came through the speakers sounding like chipmunks. You've heard the Alvin and the Chipmunks albums, that's what it sounded like. It didnt matter if it was a Windows sound (wav file), and MP3, a WMV, or any other multimedia. Everything sounded like a chipmunk was playing it. The sounds were played too fast and too high pitched.
Her computer is an Acer with a Realtek sound card built into the motherboard. It has the Realtek HD Audio Manager built into it and I thought at first that something had changed with the audio settings. However, after examining the audio utility and choosing to reset the environment back to its defaults the chipmunk sound was still present.
he Realtek Manager also has an option for Karaoke Mode, which basically removes the voice track when playing a song. Changing this feature had no effect on the system.
Uninstalling and Reinstalling the Sound Card
The only way I found to truly fix the issue was to uninstall and reinstall the Sound Card. Follow the directions below to accomplish this.
1) Open Device Manager by Right-clicking on My Computer and choosing Properties. Then click on Device Manager
2) Under the Sound, Video, and Game Controllers section, Right-click on Realtek High Definition Audio and then click on Uninstall.
3) Close the Device Manager and Reboot your computer
4) After the computer reboots, allow it to automatically find the Realtek audio device on its own and reinstall the drivers. You may be required to reboot the computer a second time after the drivers for the sound card load.
5) Test the sound card by playing an MP3, WAV, WMA, or other sound or by watching a video online.
The problem should be fixed. If for some reason, you are still experiencing a chipmunk-like sound coming from your speakers, visit the sound card manufacturers website and download and install new drivers for the sound card.
on Jun 25, 2010 • Computers & Internet
2answers
Microsoft Solitaire Helpline Call 1-8O5-225-6690 We are 24 Hour Available Call Now
Even though you say you did not mess with the settings, I'd suggest you check the audio recoding settings in Vista anyway. Better make sure all those are correct.
If you are using an internal microphone, I'd suggest trying an external one (if you already have that, try a different one). Even a webcam with built in mic will do. That way you can isolate the cause.
Based on my experience I'd say that chances are bugger that it is a loose contact, so make sure to check your plug if it's an external mic.
Jules
Distorted sound (voices sound like "Alvin and the Chipmunks"
Have you tried another set of speakers? If not I would do so cause your speakers might have just gone bad!
Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Pantech duo voice mail keylock issue
try sending the call str8 to ur voicemail so u will be back into the regular call menu
Alvan and The Chipmunks reside in my Gmax 2100 speakers!
If you have a sound card added on your motherboard, i suggest you uninstall the drivers, take off the sound card, attach it again and install the drivers.
If you connect your speakers through the motherboard itself, uninstall drivers and install them by searching C:\WINDOWS\system32\drivers
Hope it helps!!!
2answers
My Sound-card sound like
check device manager for your sound card, and tell me what it is. also, your software your sound card uses.
most sound changes comes from the software.
The microphone cuts out
Normal 0 Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
