Apple iMac 17" Desktop Logo
Posted on Jul 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it off and reboot. I've done all the maintainence including Diskwarrior, Cocktail, Onyx, HD checks OK as does ram.
Anonymous
Level 2:
  • Apple Expert 481 Answers
  • Posted on Jul 14, 2010
Anonymous
Apple Expert
Level 2:
Answers
481
Questions
Helped
175850
Points
801
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
  • Anonymous Jul 14, 2010
    One other test: get an external display and hook it up to the iMac through the display port. When your main display goes out, does the other display also go out? This is probably the diagnostic that will tell you the most about where your problem is. My first suspect is a bad inverter or backlight, which won't affect the other display at all. But if both go out, then you're likely looking at a graphic processor or logic board problem, which is expensive.
1helpful
My Gateway GT5408 - tower - Core 2 Duo E4300 1.8 GHz - 1 GB - 320 GB, won't come on
Kindly check if the lights are on when u boot up the PC, furthermore, if you have air blower, clean it once, and remove the rams from the ram slots and install again, if u have more than 1 ram installed, install one ram at a time to check if there is any faulty one.
1helpful
2answers
My safari crashes on my laptop after about 10 seconds. I've tried several times. I've also tried to download again. I have a Macbook Pro, OS version 10.5.8, Processor 2.4 GHz, Intel Core 2 Duo,...
The first thing you should try is resetting the PRAM, this can be done by following this guide.
Then use the Finder to view your User/Library/Cookies/ folder, and drag the Cookies.plist file to the trash. now try Safari again.
If that cures the problem, then we know the cookies file was the reason.
Unfortunately you may lose various website settings and passwords, that were stored in the cookies.
If the problem still persists after this I would try calling apple support.
How to install additional memory on my 24" iMac.
maybe this will help.
http://www.youtube.com/watch?v=bZLewEVOuTw
2answers
Cannot install final cut pro.....the software says my macbook pro(macbook3,1) does not have minimum system requirements. my mac.... 2.2 ghz 800mhz core 2 duo 4gb ram 2x2gb @ 667mhz GeForce 5600m gt 128mb...
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry.
ken
Laptop shuts down during start up
you must to reinstall or format your operating system
4answers
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Processor Error
Possibly a clock error or bios setting error. Thats an odd one !
4answers
Installing Leopard on my iMac
Yes you will have to clean the disc.
But if you have another mac hook it up to another mac, boot in firewire slave mode, and save thefiles.. (http://docs.info.apple.com/article.html?artnum=58583)
Adding Ram
The RAM should be fine running along side each other but make sure you check the motherboard specs install the RAM leave running for 5-6 hours see how it goes also try memtest86 on your system here is the link
http://www.memtest86.com/
Regards,
Spud
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
