GE WDSR2080D Top Load Washer Logo
Posted on Apr 19, 2008
Please help My washer started doing the exact same thing 3 weeks ago. Mine will work perfectly and then stop. No sounds from the motor at all. After it sits for a few hours it will work perfectly again... washes fine then starts to spin FOR A FEW SECONDS then quits. It started this about 3 weeks ago then started working perfectly for about 2 weeks... now it is on the blink again. One more thing I have noticed is that if you leave it on the timer will get to the spin cycle and drain all of the water out as if the system is actually about to spin. Once the timer gets to the spin cycle it goes silent completely. No hum or anything from the motor. just like it is turned off. ANY HELP WOULD BE MUCH APPRECIATED! THANKS. SYNOPSIS: 1 FILLS NORMALLY 2 WASHES FOR A FEW MINUTES 3 DRAINS NORMALLY 4 SOMETIMES SPINS FOR A FEW SECONDS THEN CLICKS ON AND OFF BETWEEN TRYING TO START AND STOP... THE WASHER DOES SPIN WHEN IT ATTEMPTS.. AND SOUNDS NORMAL.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Apr 27, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
4527
Points
35
It is the timer or, it may be a short of some kind
1helpful
Mabe fridge stops working every 15 minutes. Is that how its suppose to work?
Question edited for better English and CAPS for maker name.
Yes, that is exactly how it is supposed to work and is called 'cycling;. 15 minutes between cycles is perfect. What happens is this. Your fridge is at the perfect 3' centigrade (37.4 Fahrenheit), so it cycles off the compressor motor, 15 minutes later the temperature rises to 3.2'C (37.76'F) so the compressor cycles on for a few minutes and pulls the temperature back down to 3'C. If you are opening and closing the door or adding things at ambient room temperature like supermarket produce, the compressor will stay on longer to get that perfect temperature and cycle off.
If it is doing it every 30 seconds, that is called 'short cycling', and it would need attention.
2answers
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
1helpful
My blower motor works intermttently. If it stops i hit the motor and it usualy starts again. Can anyone help?
Had same thing, dealer replaced motor, started same thing. I took motor out cleaned, put 3 small washer between motor & housing. Bolted up, fan was hitting housing & stopping or rubbing. Just needed space between motor & housing. That was 2 yrs ago.
Escort 55 1.8d van fuse 25 keeps blowing and cant start my van.circuit says wiper and washers and it wont let me install new fuse without blowing.i have work on monday !Help!
Unplug the wiper motor and replace the fuse. If it works the wiper motor is shorted out. It may also be the wiring rubbed thrue somewhere causing a short.
4helpful
5answers
I have a pioneer avic-f900bt and it keep turning off. it powers up for a couple of seconds and then it shuts off what could that be please help me.
I appear to have the same issue with mine. I purchased mine from Audio Itch in Tampa, Fl in December of 2008 and had them install it with an amp and speakers. Worked fine for almost exactly a year. Upon starting up my car, it powered up and gave the system powering up notice, then went blank. Rebooting with the small restart pinhole button sometimes works, but most of the time it will start powering up again, then shut off????
1helpful
Humming sound from the washer
Sounds like the pump is locked up for some reason could be something stuck in it,I have pulled a lot of nickels out those for some reason, they are the perfect size to get down into the pump and get stuck.
2answers
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Malber P21 - works slower and slower
hi from uk from what you describe /symptoms this is sure to be the motor brushes are worne very low and req renewing this is not beyond the d i y novice and the 2 x brushes for the motor here in uk cost approx £5 and easy job to renew if you remove rear panel off machine then remove motor you will see how it looks and secures just like a car alternator and also belt adjustment is same the brushes will be self explanitary of how they are renewed once motor is removed ? hope this helps/inspires you and will save you $$$$s by diy
1helpful
3answers
Car reving up and down on its own 3 to 4 times, then sputtering and dying?
The previous solution to check the idle air contol is in the correct area but needs some clarification.
The idle control is accomplished by two parts: Throttle position sensor ( $35 at Autozone) and idle contol valve approx $190. I replaced the throttle position sensor about a week ago and it runs perfect
to date but am a skeptic after almost two years of dealer incompetance. I researched all the sensors and failure symptoms on the internet and the throttle position sensor failure symptoms matched mine
exactly. See http://wiki.seloc.org/a/Throttle _Position_Sensor
2answers
My frigidare glws1233a top load
Do you have this noise when operating an empty machine ? It could be cause an unbalanced load of clothes. Stop the machine, redistribute the clothes and re-start the machine. In case you still have this noise, the problem is with the transmition between the drive motor and the inner tub. Good luck !
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
