Hello: i?m Jorge Borrero from Puerto rico. i have a gps Magellan roadmate 6000T with p 800503-01. The gps is Locked and not remember the password. which is the step for reset the password in this unit? could you assistant me in this case please? kind regards att. jorge Borrero
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
SOURCE: I have a Magellan 6000t locked because it needs a password.
Power unit up from a completely off state. While it's starting up, hold the Mute and Menu buttons down the entire time. It will start up, then flash. As soon as you see the flash let go of the Mute and Menu buttons. Then, as soon as the lights come on around the unit quickly press and hold the Mute and Menu buttons again. The unit will boot into the Windows CE operating system. You then double click on My Device and delete HDD3 or, if you have a SD card in the slot, cut and paste the HDD3 to the SD card. Power the unit off holding the power button down for 7-10 seconds. Take out the SD card, if you have one in, then power up the unit. It should restart likes it's fresh from the factory. I will not be held responsible for any problems or bricked units! DO THIS AT YOUR OWN RISK!
SOURCE: I have a Magellan Roadmate 6000t and I Love it. I
if you have the 6000 NA (north America) version, you can get a map update HERE and get the latest maps.
if you have the Europe version, go HERE
i recommend you also get the update for your unit if you haven't already.
bill
SOURCE: Hi, I bought a used Garmin
Follow the below procedures. You would see the amount you would have to pay in the process.
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Good luck.
