Cosco Juvenile Samsonite Cosco 11-839GGO: Commercial Step Stool Logo
Posted on Jul 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a similar step stool which is missing the two caps where the front legs meet the rear legs. Where can I purchase these caps?
Anonymous
Level 2:
Champion:
  • Expert 225 Answers
  • Posted on Jul 10, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
225
Questions
0
Helped
144862
Points
371
Menards or lowes carries them.
  • James Kirkpatrick Jul 28, 2012
    You are talking about the feet. He's talking about the molded cap that keeps the rear leg top alinged to the front leg/frames when the stool is opened.
1helpful
I need the instructions to assemble my retro step stool
Hello, Debra -
You do not state if you purchased your step stool new or second hand. If you purchased it new and still have the sales receipt, I suggest you return to the store (or contact the online seller) and ask for the assembly instructions.
The image you attached looks like a step stool manufactured by Cosco. Does the step stool have a label with a maker name and model number printed on it? If it is a Cosco and if you can find a model number, you may be able to obtain assembly instructions here:
https://www.coscoproducts.com/eng/instructions
That web page also has a link to contact the company if you do not have a model number.
Best wishes.
May 04, 2018 • Furniture
I have a model 875.498601 workshop stool need to know how to remove the floor protector on bottom of the stools leg, have to install another one
The plastic foot is adjustable snd covers a bolt that is threaded into an insert in bottom of leg. Should be able to unscrew it by hand (if new), or use a pair of channel locks
Jan 05, 2017 • Furniture
I Purchased a swivel stool, 068-0932-2 (29" stool) and it was missing the 4 leg parts (Part D). How do I obtain these parts?
I would return it where I purchased it. I find Canadian Tire has been very good when I have to return items.
Problem with polder 3-step ladder
If you are experiencing a problem with the feet on your Polder 3-step ladder, you may be able to find replacement feet for the ladder through the manufacturer or through a retailer that specializes in ladders or home improvement supplies. You can also try contacting Polder directly to inquire about purchasing replacement feet for your ladder.
When requesting replacement feet, it may be helpful to have the model number and serial number of your ladder available, as this can help to ensure that you are purchasing the correct parts for your specific ladder. It is also a good idea to confirm that the replacement feet are compatible with your ladder and meet any necessary safety standards.
If you are unable to find replacement feet for your Polder 3-step ladder, or if you are having difficulty determining the best course of action to take, you may want to consider consulting with a professional repair service or the manufacturer for further assistance.
1helpful
Where can i purchase the rubber treads for the steps on a cosco step stool
http://www.coscoproducts.com/eng/Products/Step-stools/
http://www.coscoproducts.com/eng/Contact-Us
I'm guessing this is an older stool you have that you need to repair. the model number you provided doesn't ring any bells at Cosco.
Give them a call or send them an email and see if they can help. You're other choice is to look at a hardware store for something to use to replace the worn treads. Good luck.
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
Jul 24, 2012 • Furniture
I have a few swivel bar stools in my kitchen but two of them are squeaking, how can I fix them?
First turn the stool on its side and check all the bolts on the legs. If they are ok, rest the bar stool upside down so you can get a look at the underneath of the seat. Check the bolts there too. Once you are sure all bolts have been tightened return the stool to its upright position. Next you will need a can of high quality lubricant which you will need to apply to any squeaking area.
7helpful
How to unstack a dryer
I have a Kenmore 417.69042990 stackable dryer and had a similar problem. To unstack it, in the front of the dryer there are two screws that are covered by round caps. They are easy to miss unless you look for them. Remove the caps, and the screws underneath it. Now, voila, you can lift the front of the dryer and pull as to unlock it from the two brackets in the rear of the dryer. Hope this helps... I took me and my husband over an hour to figure this out...
Nov 11, 2007 • Dryers
Top Cosco Juvenile Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Cosco Juvenile Tool and Hardware - Other Expert? Answer questions, earn points and help others
