I have an Emachine T2542 with Windows Xp. I had it turned on yesterday and was in the middle of editing some photos, when it shut off. There was not a shutdown screen or anything. It just turned completely off and now it won't turn on. I checked the outlet on the power supply it's plugged into and it is getting power.
It looks like your computer's power supply unit is gone. This is common with the eMachine T2542 series. Unfortunately, sometimes this destroys your motherboard as well.
HERE is a thread I found on another forum relating to the same problem. I guess you'd be better off trying to invest in a better machine. Sorry I can't be of more help. But do go through the link I posted, you may find it helpful.
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
You need to open the PC and check the power supply for some fuse and safety device that acts like a fuse , these fuse looks like a 3 leg transistor only that it have 2 , look for this , and of course the typical fuse . hope it helps
My t2542 keeps shutting down after about twenty minutes. I have replace the hard drive, power supply twice, reset jumper settings, and am about to conceed to the fact that it may be in the Mother board. It stays on to get through the boot but unpredictable when it will reboot.
