1999 Ford Taurus Logo
A
Anonymous Posted on Jul 06, 2010
Generic code PO171 system 2 lean bank 1 generic
Generic code PO171 system 2 lean bank 1 generic code PO174 system 2 lean bank 2 manufacture code P1519 continuous intake manifold runner control closed bank 1 seep2006
  • Anonymous Mar 17, 2014
    system too lean bank 1 PO171 what does this code mean ?
Jim
Level 3:
Genius:
  • Ford Master 1,230 Answers
  • Posted on Jul 09, 2010
Jim
Ford Master
Level 3:
Genius:
Answers
1230
Questions
0
Helped
360304
Points
3262
This can be caused by a faulty mass air flow sensor
  • georgw
    georgw Oct 22, 2013
    i changed it
What do the following codes mean? PO171,PO174 and PO430. And what is best solution to eliminate them? Is it something I can handle or should I carry it to my local mechanics?
PO171 Fuel System Lean Bank 1
PO174 Fuel System Lean Bank 2
PO430 Catalyst System Low Bank 2
A new fuel filter would be a good start.
Po171 po174 code
Lean bank 1 and bank 2 , and throttle actuator system fault. Check reason for lean codes 1st, vacuum leak(s), air inlet boot and hoses, or low fuel pressure / clogged filter. Repair as needed then clear codes and recheck .
Check engine light is on and when tested shows codes PO174 and PO171
The P0171 means System too Lean (Bank 1) and P0174 means System too Lean (Bank 2).
_______________
FGTech Galletto 2-Master
Which 02 sensor is faulty on bank 1, with the Generic error code PO171? (system too lean).
bank 1 is the side of the motor cylinder 1 is on.there fore bank 1 sensor is the sensor in the exhaust that comes off of the head wear cylinder 1 is.
5helpful
Error codes PO171, PO174 on 6.0 2004 silverado, what are they?
P0171 means: System too lean (Bank 1) P0174 means: System too lean (Bank 2). Sounds like your injectors are not getting enough fuel.
Check engine light is on codes are po171 system too lean (bank 1) po174 system too lean (bank 2) so what can i do
Look for vacuum leaks,that are causing the O2 Sensors to go lean, and set codes on both banks
1helpful
97 Mercury cougar xr7 v6. po443, po430, po171, po174,
Sounds like you have low fuel supply or a leak in intake system causing lean codes, check fuek pressure and volume first. Cat converter effeciancy could be caused by the lean codes, purge system sounds like solenoid failure, check for high resistance accross purge vent solenoid.
3helpful
What do these trouble codes mean p0171 and p0174
po171 is system too lean,bank 1,po174,is system too lean,bank 2,It sounds like a fuel pressure problem.
1helpful
1995 Windstar OBD II showing codes PO340, PO171, and PO174
Hello;
With those codes, the first place I would check is the fuel pressure. Also check the fuel filter and replace it if you haven't already. Then clear codes and recheck. Even if your fuel pressure is with in range it still may not push enough fuel to operate your vehicle.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
