Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
I have the same problem with my go-cart B&S Engine, All I see on here is the gas tank is vapor locking, I loosened the gas cap, even removed it,. still trying to get to the bottom of it. Frustated, I thought I'd someon here,
I have the same problem with my go-cart B&S Engine, All I see on here is the gas tank is vapor locking, I loosened the gas cap, even removed it,. still trying to get to the bottom of it. Frustated, I thought I'd someon here, but no luck, I am going to look into the coil when it is hot to see if it is loose/ broken wire or otherwise test the coil with a cheap tester... if you have any other feed back here, please post -- THANX
I have the same problem with my go-cart B&S Engine, All I see on here is the gas tank is vapor locking, I loosened the gas cap, even removed it,. still trying to get to the bottom of it. Frustated, I thought I'd someon here, but no luck, I am going to look into the coil when it is hot to see if it is loose/ broken wire or otherwise test the coil with a cheap tester... if you have any other feed back here, please post -- Best Regards, Ck
