I looked up the PDF for your camera, and it says: "use only an SD memory card or a Multimedia card with this camera. Proper operation is not guaranteed when any other type of card is used." I did not see a maximum size listed, but some cameras only accept 4GB, some 8GB. I think the important thing is "use only SD card".
SOURCE: memory card blocked!!
First of all with a Casio camera Casio will only guarantee the camera to work with Panasonic, Toshiba and Sandisc memory cards. If it is not one of those three brands I would go buy one of those brands. Make sure you format your memory card with the camera before using it for the first time. As for the other memory card try using a program like cardrecovery.com and see if you can still pull your pictures off that card. I bet they are still there. :)
SOURCE: Camera Memory Card Capacity
The casio ex-z750 does not support SD HC cards. (Almost) Every card that is 4 GB or higher is an SD HC card. This is why the cards don't work.
SOURCE: I bought 2 16gb sdhc cards and cant format them in
you can try to format them on your computer if you have sd drive. Otherwise I would suggest returning those ones and get something different. Sandisk is a good brand.
SOURCE: Why won't Kingston SDHC 4 gb card work in Casio EX
The EX-Z57 is designed to work with SD cards, not SDHC cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
SOURCE: Will a 4 GB ScanDisk SDHC memory card work in my
No. The EX-S600 works with MMC and SD cards, which max out at 2GB.
