Amana ACEX186E Wall/Window Air Conditioner Logo
Posted on Jul 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Energy saver feature turns off unit but won't allow to restart or will just humm
Anonymous
Level 3:
  • Master 455 Answers
  • Posted on Jul 08, 2010
Anonymous
Master
Level 3:
Answers
455
Questions
0
Helped
143146
Points
1102
Hello Jester The unit needs 5 minutes between running and restarting.Humming could mean overload let it cool.Turn it off 20min.Turn power saver off on HOT days.
My Canon image class MF5350d won't go into energy saver mode anymore
Odds are that some one did some panic button pushing at one time. You need to look in your owners manual or down load one from the web. Or you can go into the user settings and scroll down to were you see a setting for energy save. Good Luck
1helpful
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
1helpful
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
3helpful
2answers
What does energy saver do ?
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
2answers
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
