You can buy a cheap meter from maplins or screwfix for less than a fiver which you can use to test the fuse.
Check all internal wiring connections are true, test in a different socket. There is the possibilty that the motor failure may have blown the main pcb (263909) or the on/off switch (167321) is not operating.
Good luck.
