All hard drive manufacturers have utilities you can download from their web sites that will write all zeros to your hard drive from a bootup environment.
Then if you get a hold of a copy of Hiren's Boot CD, you boot to this from your CD/DVD drive and select Hard Drive utilites and there is a program called wipe disk.
A free program called GDISK, will wipe a drive according to DOD standards. It doesn't com with a boot loader you can use to boot from your CD/DVD drive, you need to use Nero Express to create a bootup disc using the built in boot image from Nero, add GDISK to it and then once you've booted up, you type the command
gdisk /?
And you will subsequently see command line codes to do a disk wipe. Through trial and error you'll get this right unless you are already comfortable with command line structure.
Hiren's is the best tool and invaluable to have around.
You can find the home page for it here.
Regards,
Worldvet
What is the question here?
Can you tell me how this happened, or what makes you believe your hdd has been wiped. There are solutions if this has happened, i.e reinstalling your operating system, but it does meen you have lost everything. Come back to me if you want to proceed?
