Gigabyte RADEON HD 4650,  Video Card Logo
A
Anonymous Posted on May 06, 2017
I am not a computer person but we did install a new Radeon hd 4650 video card in my son's hp. The Best Buy Geeks looked it up for our model and said it was compatible. We put in a new power supply. The picture works but no sound. Doesn't recognize the speakers at all. Says nothing is plugged in and there is no volume bar at all. We did updates on drivers and don't know how to take it all apart and redo it. Why is there no sound now? When we check device manager it says ati is our audio driver. So we can't figure out how it isn't working.
Level 3:
  • Gigabyte Master 6,688 Answers
  • Posted on May 06, 2017
Cindy  Wells
Gigabyte Master
Level 3:
Answers
6688
Questions
0
Helped
3532733
Points
21745
Are your speakers plugged into the 3.5 mm jack on the system?
When you install the Radeon driver, it can sometimes change the default audio output to the HDMI port on the video card. For various Windows OS versions, you need to set this in the audio section of the Control Panel. The specifics may vary. For versions before Windows 10, Click on Start and select the Control Panel. Then choose the Hardware section. Find the Sound section and Manage Audio Devices. In the Playback tab, right click on the correct audio device (Speakers) and select Set as Default Device. Depending on the system, you'll probably see AMD HDMI Output and Digital Output. For Windows 10 before the Creator Update, right click on Start and look for the Control Panel. After the Creator Update, you'll need to click on Start and expand the Windows System folder.
I hope this helps.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Jan 29, 2010
SOURCE: Gigabyte Radeon HD 4650 1GB (AGP) - unknown PCI device
Hello.
ATI (AMD) does not "technically" support AGP products, but go to this link.
http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
To download the driver. Versions 9.6 and 9.7 will work, depending on your OS. Just download and install the drivers and the yellow exclamation mark will go away.
For more information please visit: http://forums.amd.com/game/messageview.cfm?catid=260&threadid=117644
Hope that Helps.
HD 4650 driver
You can get it here:
http://support.amd.com/us/gpudownload/Pages/index.aspx
Just select Desktop Graphics
Then select Radeon HD series
Then select Radeon HD 4xxx series PCIe
Then select whatever operating system you are using
1helpful
Windows 7 do not accept (my Sapphire 4650 Hd Agp ddr 2 1gb graphic card) drivers when I upload drivers .how I will make upload for my computure?
This is Sapphire's link for downloads:
http://www.sapphiretech.com/presentation/downloads/download_index_01.aspx?psn=0006
I entered your info and it appears the card #100288L Radeon HD 4650 1GB DDR2 has Windows 7 support. This card requires a 400w or greater power supply and, a 6 pin power hook up. You have to un-install the VGA driver and Catalyst control center before downloading new. You can do so in a "custom" uninstall then, a "custom" install.
http://support.amd.com/us/Pages/AMDSupportHub.aspx
You can also try to update your drivers here.
1helpful
2answers
Here's my system: MSI MS-7184 Motherboard AMD Sempron 3200+ 1.8GHz 2GB RAM Windows 7 Home Premium 32-bit Problem: I bought a Powecolor HD 4650 1GB DDR3 and when I inserted it in my computer. It...
Judging from the symptoms you describe I suspect that your graphics card is faulty. Did you buy the card new? If so, I would suggest returning it & asking the store to test it for you.
If it is determined that the card is not faulty, reply to this post & I will try to help you further.
Best wishes,
Graemevm
Nao acho drives para shapphire ati haden ah 4650 ddr2 hdmi
Hello seraphim_asn,
go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://www.amd.com/us/products/desktop/graphics/amd-radeon-hd-6000/Pages/amd-radeon-hd-6000.aspx
1helpful
I installed a radeon hd4650 and now I have no sound. It says in device driver that there's no audio device. I do not even show a volume control. Help!
Sounds like the video overtook the sound driver i would try and remove and replace your sound card or if it is onboard sound remove and replace the driver. Also try and find an update for the video cardthere might be an update on that issue.Best of luck.
Tom
Hello.
Hope that Helps.
1helpful
I have an HP 854n computer. what type of graphix card do i need?
Hello there:
ATI Radeon HD 4650/70: Top Value for Bottom Dollar would be the best for this computer ok
best regards michael
8helpful
2answers
Radeon HD 4650 = NO audio
uninstall the ati sound utility, these video cards have a built in high def audio chip for sound thru hdmi
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
