Question about Ryobi Multi-Volt Battery Charger
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
    New Friend:
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Posted on Jul 17, 2010
  • jeriatric May 03, 2014
    The C batteries are compact 'Sub C' batteries and not the standard C batteries you find in the hardware store...but are easily found with a google search The milliamp ratings must match. The milliamps (mah) can range from .1200 mah to 3500 mah. The type of battery should not be mixed; ie Nicad, Metal hydrided, Lithium. You can 'flash' the battery pack (a 12 volt car battery will do) by momentarily tuching the positive and negative contacts on the battery pack. This will 'flash' away the tendrites that are shorting out the weak Sub-C battery. This is only a temporary solution (not to be used with Lithium batteries).to give you a little more life to a dying battery.
  • 487 Answers
Hi, it is more likely your batteries are worn out, they don't last as long as the drill
Posted on Jul 07, 2010
    New Friend:
Yellow and green lights: It is possible to FOOL THE CHARGER INTO icharging the 18V battery pack. You may get a few more uses out of the battery pack doing this, it is not a permanent fix.
This sounds a little crazy but it works. And sorry I don’t know why it works, but it does.
• Plug the charger in into the wall and insert the battery into the charger. You should have the notorious yellow and green light on.
• As quickly as you can unplug and plug in charger about five or six times in a row, faster the better, until the yellow and green go out and the red turns on. This may need to be repeated several times.
As I said, it works, I don’t know why, but it does.
Posted on May 30, 2018
  • Jay Kay
    Jay Kay Jul 03, 2018
    Nicely done — this just worked for me. Thank you very much for the tip!! It’s only a matter of time until I replace all these @#$%$#@! Ni-Cad/NiMH batteries with Lithium Ion. Unfortunately, I bought a boatload of tools that use these @#$%$#@! batteries (Ryobi and B&D Firestorm). Ugh! Does this trick work with Firestorm NiCad batteries too??
6ya staff
SOURCE:
Ryobi 18v battery charger is not charging
If yellow and green light come on and stay on then your battery is bad if not get a new charger
Jul 22, 2014 | Ryobi 140237039 18V Ni-Cd Battery Charger
My ryobi 14.4 v cordless, when i put the battery in the charger the yellow and green light both stay on and does not charge. this happens with both chargers and battery packs
If i have this striaght two chargers and the green and yellow lights are on and the batterys will not charge and there 14.4v batterys correct . Then the batterys must be no good unless bolth chargers are bad and have the same problem witch is exterimly unlikely. most likely the batterys and are NG.They don't do well if left in cold condutions or hot for that matter but cold is worse . 14.4 V is is an unasul size and if its not a lithuim ion battery its going to be obisilete and unavaible soon if not already . Ihad the same problem with my RYOBI 7.2 volt can't get the batterys for under a 100 dollars thats one and a speical order i paid 39 dollars for the gun and 2 batterys . They make the money off resale on batterys . And you can do far better then RYOBI for a screw gun now a days
Sep 09, 2011 | Ryobi 18v Cordless Drill - P206 18 Volt V
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
We have a Ryobi P100 Battery and a P110 charge. The battery became very hot while using it and die very fast. When trying to recharge the yellow and green light come on the charger. What is going on?
It sounds like you drained the batteries down as far as they will go. This happened to me and then I purchased the 18V Lithium-Ion battery and charger. I was able to re-charge the drained battery on the new charger. This may work for you as well. They cheapest solution for you is to just purchase a new battery.
Nov 14, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18V cordless drill the yellow and green light is on when charging what does this mean
I have found when I put a battery on to charge and the green and yellow light turn on the battery is low voltage and the charger will not charge the battery ( bad battery)
Nov 12, 2009 | Cars & Trucks
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Oct 06, 2009 | Ryobi Multi-Volt Battery Charger
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi Multi-Volt Battery Charger Logo
5,060 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
