Computers & Internet Logo
Posted on Apr 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ASUS P4T533-C Manual is not complete. I can not find the wiring diagram that shows the connections on the front panel blocks on my mobo. I need to find where to connect the following case wires to my mobo. Power switch, Reset switch, HDD Led & Power LED.
Anonymous
Level 3:
  • Master 472 Answers
  • Posted on Apr 18, 2008
Anonymous
Master
Level 3:
Answers
472
Questions
Helped
190929
Points
1152
This is the bit your after I believe...
Georgia B
Level 3:
Guru:
  • Master 1,342 Answers
Georgia B
Master
Level 3:
Guru:
Answers
1342
Questions
0
Helped
879371
Points
3834
This should explain everything
Please vote if you found this information useful.
Thank You
2answers
Pls. front panal wiring diagram for asus p4ds-vx
any manual will be at SONY, this mobo is a contract made.
Asus, to sony, and made to SONY SPEC.
one poster said
from my SONY vaio pcv-rs346. (and is)
no service manuals sorry or gee ask SONY.
what you do is plug in the front panel connector.
it is keyed
but you lost the front panel assembly didn't you.?
why play P4 relics, 99% are in the landfill.
it is possible that asus used there standard(internal) wiring
here and only changed like 3 times in 20 years.
2003 made PC, it is, a true fossil.
or ask the bad boy that sold it to you.
did you also lose the sony VAIO PC casing?
sorry i can't see it to know know what's UP DOC.
here it is sold just like this, rs346
the panel has 6 , cables and are not documented
they simply plug in. (lost this did you? ) use the word lost or?
sony-undefined-undefined-0_0.jpg this is the real part, had to search very old sales transactions.
but there it is in all its relic glory. worth exactly zero.$
Need wiring diagram for client pro 365
What was your original MOBO? It should help you identify the connections to your chassis/front panel.
Typically you will have USB, audio, ground, power supply and switching/reset lines.
Often the connectors are not compatible and you need to improvise.
A manual appears to be here for Intel 915GRV uATX Motherboard (ClientPro 365) (MBD001246-00):
http://www.mpcdrivers.com/apps/compdeteb4e.html
Use at your own risk. MPC died some years back and this is the official MPC/Gateway support site per Wikipedia http://en.wikipedia.org/wiki/MPC_Corporation
Need connection diagram for awrdacpi motherboard need front panel connection diagram for awrdacpi motherboard...I need front panel connection diagram for awrdacpi motherboard
http://support.asus.com/download.aspx?SLanguage=en&p=1&m=M2N-MX+SE&hashedid=LqXTJVvWNyI6cj2d
Download the installation manual in your language from there.
1helpful
2answers
I want to get a usb 3.0 hub and plug it to the asus p8p67 pro on the middle of the mother board. What kind of connection is it?
The header bus above is for the USB Front Panel interface:
This is included in many of the various flavors of the MoBo. If you're looking to use the MoBo connector to supply something other than this Front Panel interface, you're going to need to obtain the pinout of the jack on the motherboard and compare it to the signals required by your USB 3.0 device. The one from Asus is simply gathers the wires and forms them in a single shell - then keys the shell to prevent reverse insertion.
Think of what you have to do as the way USB 2.0 headers are provided on MoBo and the way PC cases have USB jacks built in. The USB header isn't standard; some have 9 pins - some even have 10! They can't seem to get on the same page as to how many pins are needed. The location of the signals on the header are probably different from brand to brand, too. So, the case manufacturers break up all the individual wires and label the signal so that YOU can check the MoBo manual and plug each one in to the correct pin.
Hi, im trying to connect motherboard intel D865GVHZ front panel to connection J9H3, i need a diagram for it. Thank you for your help
I may be confused with your problem you posted mar13974.
I thought Jumper J9H3 was for the Front Chassis Fan.
By your post, it leads me to believe you want the pin assignments for the Front Panel header on the mobo.
At any rate let's go to Intel Product Support, and the download page for the motherboard manual, for the Intel D865GVHZ desktop mobo,
(MOtherBOard),
http://www.intel.com/support/motherboards/desktop/d865gvhz/sb/CS-010872.htm
Click on the blue file name - D865GVHZ_ProductGuide01_English.pdf
After you click you may not see anything happening for up to 30 seconds. The file is downloading in the background.
(Took 16 seconds for me just now with a medium speed DSL connection)
Page 33 shows the location of the Front Panel header on the motherboard.
(C)
Page 34 details the pin assignments
Page 36 shows the Front Chassis Fan header location (Chassis front fan)
3-pin header, doesn't state the pin assignments.
With a 3-wire fan cable,
A) 1 wire is the Power wire. Generally Red
B) 1 wire is the Ground wire. Generally Black
C) 1 wire is the speed sensor wire. Reads how fast the fan is spinning in Revolutions Per Minute
(RPM) Generally Blue, but it's up to the individual manufacturer.
If the above isn't what you had in mind, please state in a Comment.
Regards,
joecoolvette
2helpful
2answers
Just got MOBO from friend, wanted to test, but cannot tell if any jumpers are missing...is there a map available for the Asus p4s8x-x rev 1.01?
You can download the whole manual for this board from the ASUS site here. Here's the diagram showing the front panel connector:
Hope this helps. Thanks for using Fixya!
How to connect front audio panel in a asus p5p800-mx mobo
Hello there.
I understand that you need to connect the front audio panel to the motherboard.
The user manual which came with your Computer will have the steps and illustrations to connect the front audio panel to the motherboard. If you have the manual that came with your Computer please refer to that.
If you could not find the manual you can download that from ASUS website. The below link will direct you to the download manual page.
Click here to download
or
Copy-paste the below link in the address bar of a web browser.
http://support.asus.com/download/download_item.aspx?product=1&model=P5P800-MX
Thank you
Good bye and Take care
Raviteja
Wiring manual for a thermalrock oceandome
Go here for complete motherboard support : http://support.asus.com/download/download_item.aspx?product=1&model=P4P800-E%20Deluxe Click on the + next to manual and it will take you here : http://support.asus.com/download/download_item.aspx?product=1&model=P4P800-E%20Deluxe  . Scroll down near the bottom of page to this copy : 'P4P800-E Deluxe User's manual for English Version E1867". Download a copy of the PDF file to file for reference.  I checked this manual and it has all the information you need, but you will have to quietly study it, and then print or  take down all the required information you need on paper, as you will have to turn off tthe PC and power to make all the wiring connections to the motherboard. Cheers,  geonz72.
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Grand Canyon Tech
Grand Canyon Tech
