Epson TM-T88III Thermal Printer Logo
Posted on Jul 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a epson TM-T8III printer of a POS windows 7 printing slow.
I have a epson TM-T8III printer of a POS application. On windows xp the printing was fast. I purchase a new system running windows 7 and the printers are extremely slow in printing although I installed the windows 7 printer driver.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 26, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469919
Points
19564
I have a EPSON TM-T88III running off WINDOWS 7 professional. I have upgraded from WINDOWS XP. MY CASH RECEIPT PRINTER IS NO LONGER PRINTING CORRECTLY. The printer is gone slow MY Fonts print croo
Go to Control Panel - Device Manager & find your Printer i.e. little arrow by the Imaging devices. Right click the T88 & click upgrade drivers, then clik the upper choice & it will go to Microsoft & find the correct driver for that unit & install it. (must be on line) That should solve your problem If not call Epson
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
2helpful
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Epson TMU-295 prints in condensed mode with Windows 7 from web application while the same printer prints the same output in normal mode with Windows XP. How comes?
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
4helpful
2answers
I have a Epson TM-T88III as a networked receipt printer, we have a new machine that has windows 7 and I can not get a driver to install that works. Any suggestions?
Dear Clark, it seems you have a lot of money when you suggest to waste a printer 240€ value.
The solution:
Link www.epson-pos.com and register, after that, follow this path:
Thermal line printers
Choose your model
Epson Advanced Printer Driver for TM Series (the first option for Windows7)
Install it, it Works properly.
1helpful
My POS printer print so slow what will i do. How will set it?
Make sure you go into properties of printer and enable draft mode..or best dependant on your needs...otherwise install new driver from 'epson downloads' for your printer
2helpful
2answers
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
How to add a logo into the receipt printout of TM-T8III
If you're using a Windows driver, get the EPSON Advance Printer Driver (APD), logo / drawer-kick command is built-in to the driver.
2answers
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
