It is charging the battery but the battery is not holding the charge probably from a faulty batter in the pack.so the charge is going in and out at the same time. Take the pack to a battery shop that specialises in replacement batteries to have it checked out . Take the charger also for tests.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
If possible test with another charger like a car charger if you have one also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
You can try buying another battery, or by buying a charging station that could just charge your battery (incase its the charger port on the ds thats broken).
