Your only option is to get it flashed from a Service center or from a Mobile Repairing shop. There's no other solution, and moreover if it's "cpu" or "power ic" problem, hoping to get it repaired is very less. First flash it, then you'll know the outcome if it's hardware or firmware problem.
In case it's firmware or software related, it'll be Ok after flashing.
* [flashing means installing new mobile operating system]
Good luck.
Thanks for using FixYa.
• Connect your phone to a charger
and let it charge until the battery is full. Leave the phone plugged in
throughout the procedure.
Unlock the phone by pressing "*" then "unlock.
Type in the code "*#7370#" then enter your security code. The
default security code for Nokias is "12345."
Wait 2-to-3 minutes for the format to complete, then your phone will
switch itself back on.
