Canon power shot SD1200 is "shaking hand" symbol has an "x" over it
SOURCE: Canon Powershot SD1200 IS - lost Install disk
Please visit the below link to download the required software:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=18144#DownloadDetailAct
Please select your OS and download the software.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
SOURCE: Hello. I hae a
Unfortunately, this is a common problem on this model. Yet, no resolution other than getting it repaired.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If
no luck then we have to try some things that could possibly result in
damaging your camera so should only be tried if happy to take that
risk...
5. Try thumping the camera into your other hand,
by thumping into your hand you are trying to jar the mechanism loose,
by using your hand you will hopefully not do it too hard or it will
hurt. You may need to do this a dozen or so times in different places to
work. I have found the flat of the camera bottom into the flat of your
hand best..
6. If the lens is stuck in the out position then
remove the batteries and try twisting the lens first one way then the
other, do not apply excessive force when doing this or you can break
gears, you are trying to reposition not force... Likewise if the lens
looks like it is crooked you can try pushing it back into position. This
has a higher chance of doing more harm than the thump so please be
careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: card is locked on Canon
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't do it, try another card.
