Ryobi Multi-Volt Battery Charger Logo
Posted on Apr 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Charger for 12 volts 7 amp battery smf
I need to design a low cost charger for 12 volts 7 amp battery.please help
  • Anonymous Mar 18, 2014
    how to hook up a on board charger with 2 banks to a 12 volt and 24 volt system
peter evan
Level 2:
Sniper:
  • Expert 103 Answers
  • Posted on Apr 12, 2009
peter evan
Expert
Level 2:
Sniper:
Answers
103
Questions
Helped
42088
Points
334
You need to go to a **** smith store and bye a kit to do this cheers peter
1helpful
2answers
My Invacare 24 volt battery charger has output 1.4 volts, what is the problem? and how can i fix it please? thanks.
If it only has an output voltage of 1.4 volts, it sounds like it has failed internally. Take it to an Invacare service centre or retailer and ask them to check it. My guess is that it need replacing. Here is the manual for it, and it states, 24 volts at 8 amps or 10 amps depending on country of issue. It charges 12 x 2 volt lead acid cells at the same time, cleverly making sure you can't use a standard 12 volt car charger.
https://www.invacare.co.uk/sites/gb/files/csv_migration/product_docs/technical_docs/DTEC012618_1636951~C_OptiCharge_UM.pdf
You can get them on eBay and Amazon
Invacare 1123249 8 Amp Battery Charger; AC Power Line Cord
https://www.amazon.ca > Pronto-Nutron-Series-Battery-...
24V 8A Battery Charger with XLR Connector for Jazzy 1450, invacare tdx 3, Invacare Pronto M51, Wheelchair, Sunrise Medical, Quickie, Drive Medical Electric ...
Rating: 3.7 · ‎4 reviews
invacare 24 volt battery charger products for sale ' eBay
https://www.ebay.com > invacare-24-volt-battery-charger
Get the best deals on invacare 24 volt battery charger when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your ...
1helpful
2answers
Why wont a coleman model 58022 solar panel power a 12 volt test light
P/V=A
The panel is rated 6 watts at 12 volts 12 / 6 = 0.5 Amps
So in full sun the panel "should" produce 1/2 Amp at 12 Volts.
What type of 12V bulb and what is its current rating?
2helpful
I have shumacher se 82-6 battery charger and iam trying to charge my Chevy s-10 battery that is a interstate model mt-75 what setting do I put it in 6v 6a or 12v 2 a or 12v 6 a please help
Hello Hermando, I assume your truck battery is 12 volt. You would want to select 12v 2a for a long slow charge or 12v 6a for a shorter faster charge.
2answers
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
2answers
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
2helpful
2answers
2helpful
I just bought new batteries for my Pride Ultra Go Go, but can't get them to start charging when I plug the charger directly into the outlet. Help please.
1.Make sure you installed them correctly.
2.Check the voltage on the batteries. If either (or both) register less than 11 volts, either return them for ones that have 12 volts, or attempt to bring them up to 12 volts with an automobile battery charger. Once brought up to 12 volts, install them, then make sure you recharge them with the supplied charger/adapter before or when the on-board indicator it shows low (red). If the battery voltage drops too low, the supplied charger simply won't even try to charge them.
3helpful
2answers
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
2answers
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
