Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
Posted on Jul 06, 2010
Stop watch not zeroing
Stop watch not zero-ing
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3669
Points
30
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Jul 25, 2010
SOURCE: how do I zero the stop watch
Pull the winder out to either the 1st or 2nd click & use the push buttons to zero the hands in.
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 • Watches
How do I set the stop watch to zero, and then start it?
Top button start and stop. Side button returns to zero.
Dec 01, 2014 • Watches
Skagen manual 747lsxn
Stop the chrono with top button (if it is running) reset with bottom button. If hand does not zero pull out winder to position 2 and use top button to forward to zero by single steps or hold to move faster. #push winder back and chrono hand should be zeroed.
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
1helpful
Reset to zero stop watch
pull crown out to second position press start till it goes to zero then push crown back in,,,if that doesent work pull out to first position and do the same,,
1helpful
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
1helpful
How do I zero the stop watch
3helpful
The sweep hands don't align back to zero after replacing battery
Pull out the stem to the second position then push the chronograph start/stop button a few times to move the minute hand to the zero position. Then pull the stem out to the 3rd position and adjust the second hand again by pushing the start/stop (top) button to move it to the zero position. Once you get them both to top zero push the stem back all the way and screw it in tight. Tim
Jun 21, 2010 • Watches
4helpful
2answers
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
18helpful
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
