it sounds like you need to use the rewind option first to rewind the tape. If the tape isn't rewound, then you're unable to play it. And this might cause the eject issue that you're experiencing as well.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Hello. First, do not force anything!! Secondly, make sure the battery is properly charged. Next, in playback mode, try to rewind or fast forward the tape--this causes the recording, audio, etc. heads to retract away from the tape and *might* free it if that is the cause. When you open the outer cover to trigger tape eject, do you hear the tape mechanism motor running? If you don't hear anything or the mechanism is truly jammed, it will require a tech to remove the tape and repair/replace the insert/eject assembly. Send the unit directly to a repair facility unless the warranty is still in effect.---Hope I was of some help.---Rick
It's been awhile, but I believe there is a round "switch" on the bottom of the tape that is on the same edge that the tape itself faces. First you depress the "switch", and then you will be able to turn the spools that are inside the tape. If you are facing the edge of the tape case that lets you see the tape itself, you would turn the left handed spool in a clockwise direction to rewind it. Hopefully that will help you.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
