Kodak EasyShare C613 Digital Camera Logo
Posted on Jul 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dropped the camera, getting a lens error 115,0,0,212
Camera was dropped on the lens side. I can turn it on but it gives me an error message and shuts off. Anything I can do to fix it myself?
Anonymous
Level 2:
  • Expert 502 Answers
  • Posted on Jul 10, 2010
Anonymous
Expert
Level 2:
Answers
502
Questions
0
Helped
1434108
Points
774
Lens probably does not extend or retract because of a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
tip
Lens Error fix for Digital Camera
One of the mostcommon digital camera error messages has to do with a lens problem.Some cameras will just beep and not show any error message and otherswill have an error message on the LCD screen. Some camera's will try tostart, the lens will go out and then return back and shut down.Sometimes nothing at all will happen, but the lens is the reason whythe camera will not start up.
Different camera'smay give you different error codes. Some of the error codes will beE-18 for older Cannon camera's, ACCESS error for Sony, Zoom Error forFuji, lens error restart, or just plain lens error. These are themost common camera error messages, but your digital camera may have a different one.
There are manydifferent things that can cause the lens to give an error message.One of the most common causes is keeping the camera in a case or bag.The dust, grit, felt, and lint from the bag gets into the cameralenses and causes it to jam. The static electric from the camerarubbing the side of the case causes the dirt to be attracted to thelens, which makes the problem even worse. Also if your camera is in acase and the button gets pushed to turn the camera on, and the lenscannot extend it can cause the lens pins to come out of the track,causing focus problems and lens errors. Bottom line is that you areoften better off not keeping your camera in a case! It is saferwithout a case then with one.
The next problemthat many people encounter is that they drop or knock the camera withthe lens out. When this happens, the lens pins can come out of thetrack, and/or the lens can be knocked sideways, which will jam thelens as it tries to extend and/or focus and zoom. If you do drop orbang your camera against something, there is about a 50/50 chancethat it can be fixed. Many times with care the lens can be realigned,but in some cases the jarring or the realigning, will break somethinginternally, so there will be no fix for it.
If your digital camera hasa problem, you will have a couple of choices. You can try to fix ityourself, or you can try to find a camera repair shop that will fix it for you.Because of the type of problems that cause lens errors, the digital camerarepair will seldom be covered under the manufacturer warranty. Alsobe careful to get a quote from a digital camera repair shop before youauthorize the repair. Many times the repair price quoted will be morethen the replacement cost of the digital camera. If you do a search on theinternet for a camera repair shop, make sure to include any shipping andhandling costs in the repair price.
If you choose totry and repair the camera yourself then look for my tip - Steps toRepair a Digital Camera Lens.
This gives you thehow and why of your digital camera error message, and/or why your digitalcamera will/may not start up.
Steps to Repair a Digital Camera Lens
How to easily download Pictures from Digital Camera
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
on Apr 26, 2011 • Cameras
My camera is displaying error 0000018-4489-957-000, what i do ?
The screen would turn red and i would get an error message. I realized the lens lid stayed open even when the camera shut itself off. I hit the corner of the camera a few times (the side with the lens) until the lens lid shut. Then I tried to turn on the camera and it worked!
3helpful
2answers
Lens Error. Restart Camera. Camera gives this error message and then shuts off
how i would like a $ for everttime i have responded to this problem.There is dirt or sand possibly in the lens mechnism.
try blowing it out with canned air and then slapping it lens doewn in the palm of your hand a few times turn on and see if that has got it going again ( this is not a joke it is straight from the Canoin Tech) i did it to my own and it took abouyt 15 blows and slaps to get it wiorking again canon said it would cost $120 to fix it i found a Canon tech online and he told me how its done.. give it a go
Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
1helpful
2answers
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
15helpful
15answers
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
1helpful
2answers
Lens error on digital camera
I drop my camera not even that hard and now it said the lens error message.. Does anyone know how fix this? I don't want buy a new camera.. I love this camera it's a hp m 257
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
