PNY 2GB microSD Memory Card Logo
Posted on Jul 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pny 2gb micro sd memory card is write-protected, i couldn't store or delete any files. what should i do? pls help me.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 50 Answers
  • Posted on Jul 05, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
50
Questions
0
Helped
16760
Points
127
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
2answers
All accidentally deleted.
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
My pc say that i got to unprotect the songs that i want on my micro sd but i dont know how
there is a tab you need to move on the sd card. One side protects your info, the othes side allows you to move or delete info.
I have a PNY Micro Sd card and I slid the lock (write protection)
not much you can do.. try to slide the lock back, if that doesn't wrok, go shopping.. they are pretty cheap righ now..
Good luck
Pny micro sd won't copy files
has the write protect been moved
Won't store max amount of memory
I tried copying music to my PNY 2GB, too, and it stopped accepting after about 720 MB. I deleted all the music I had on it, created half a dozen new folders, renamed them, then put as much music as I wanted on the SD. I haven't tested it on my phone yet but at least it let me copy all the music I wanted.
1helpful
I bought a 2gb micro sd card ,i can"t put any files
SD cards and microSD adaptors have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
