Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Installing the flexible drive shaft from the motor to the rotor head. I pulled off the rotor head thinking I had to do this to replace a new plastic line assy. Now I can't get the flexible shaft to re-engage the motor drive. I've tried standing the unit in a vertical position with the motor on the floor hoping I could drop the shaft a couple of inches and it would line up on the way in. I've only pulled the shaft out about 4" since I tool off the head. Then, after I had the head off I saw the hole on it where you're supposed to insert a punch to lock the upper plate and unscrew the old line assy.
  • pqfdc Sep 06, 2010
    Excellent source for help and information. I was surprised at how fast my question was answered. With the directions given I was able to correct my drive shaft problem without any further problems.
    President:
  • Husqvarna Master
  • 1,545 Answers
At the motor drive end, (where the engine is).. the end of the flex drive should mate with the clutch housing. You may just need to remove the clutch-housing cover in front of the motor to access it and turn it until it accepts the flex drive.
Posted on Jul 04, 2010
Testimonial: "Thanks for providing with a good starting point to correct the flexible drive shaft. Knowing where to begin is a big help and you've done just that, saving me a lot of time and frustration. Let me know how to contact you with the results of my efforts using your suggestion."
6ya staff
SOURCE:
How to install drive shaft on a husqvarna 322l weed eater 1999 model
The curved shaft machine has a flexible drive shaft like a speedo cable, slacken the two tube pinch bolts, these are accessed on the r/h side of the grey plastic handle through holes in the plastic housing,, remove the two mushroom headed screws either side of the plastic handle,don't lose the black o rings under the screw heads, do not remove any of the plastic housing screws, now carefully draw the tube out through the plastic handle/trigger assembly, once out pull out the old drive shaft, grease the new drive shaft and push back into the tube, once fully in turn the end to make sure the trimmer head turns, now feed the tube back through the trigger housing, make sure it is fully back home and the square end of the new shaft has entered the square hole in the drive drum, re tighten the pinch bolts, start the engine, if the head does not turn, slacken the pinch bolts and push the tube further in, re fit the two mushroom headed screws.
Jun 28, 2018 | Husqvarna Garden
Mine's a bent shaft. I guess only Victa agents can replace/repair the centrifugal clutch or internal broken cable?
not necessarily--- the broken drive cable can be removed /replaced by removing the trimmer head from the shaft at the bottom
undo the clamp and if there is a small screw/ bolt into the shaft undo that as well and pull the head off
the flexible drive cable will slip out
check the ends and they should be square in form
Mostly the cable breaks but occasionally that square section will wear round
slip in a new cable and reassemble
Oct 16, 2015 | Garden
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
I Have a Stihl grass trimmer FS36. The plastic casing holding the drive shaft heats up and melt. what is the problem
If you're refering to the item i have highlighted then remove the driveshaft from the plastic flexible liner, clean shaft, re-grease and replace. You'll probably fing the shaft has become dry and has rubbed, causing it to get hot. The plastic liner should not be spinning in the drive tube assembly so you may need to get a new 'flexible liner' that fits snug.
Feb 21, 2013 | Stihl Garden
I have a Poulan 810EPT electric motor that has worked great but now my attachments won't slip and lock into the end of the shaft. Can't see any obstruction except maybe the flexible cable on the...
This sounds like the flexible drive shaft inside of the main shaft has a stripped ferrule. In order for you to fix this, you will have to take the main shaft off of the motor housing and pull the flexible shaft out of the inside. The replacement part number is 530056570 and should be about $12 to replace. Call the number on the unit to order replacement parts or go to your local sears.
Aug 27, 2011 | Poulan Garden
HOW TO REPLACE HALL SENSOR ON LG TROMM
Unplug machine. Remove back panel (4 phillips head screws). Remove large bolt in center of motor. Pull motor rotor off shaft. Remove phillips head screw(s) holding wire protector and possibly ground wire at bottom of motor area. Remove metric bolts from motor coils and remove coil assemble. Unplug 4 wire harness from Hall sensor. Unclip Hall sensor from coil assembly. Install new Hall sensor, and re-assemble. Plug machine back in. There. Done, and it only took 10 minutes!
Mar 27, 2011 | LG WM1814CW Front Load Washer
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Stripped plastic coupler on output shaft of Dremel model 277
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
Oct 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Ryobi 700r how do you replace flexible drive shaft. Boom and trimmer get very hot after the trimmer runs for a while. I think the flexible drive shaft needs to be lubricated. I can not figure out how to...
it comes out but you have to lossen the screws holding the engine on at the base and pull it out? the other end has a locking nut remove the spool and loosen
Aug 27, 2009 | Garden
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
528 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
