To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
SOURCE: lost key
i lost my keys to my sentry box 1110 and 1170 the spare keys
were inside of the boxes
SOURCE: sentry 1100 lost key
You can go to www.SentrySafeShop.com and do a search for lost keys. It will provide you with a customer service number where you can order replacement keys.
SOURCE: lost key sentry model 1170, where can I get a
A locksmith can fit keys the the sentry safe 1170. Sentry safe lost key replacement is availble. You do need to know the key # that is on the face of the lock to cut a 1170 key by code.
SOURCE: I had lost my key to my SENTRY 1170 and need my
The fastest thing to do for the portable Sentry Safe 1170 would bring it to bring it to a locksmith and have them pick the lock or fit a key to it.
