Garden Logo
Posted on Jul 03, 2010
How to adjust the carburetor on a srm-2501 echo line trimmer. When you start trimming it dogs out and loses power. Is it possible to clean the carb. or rebuild or just replace it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1857
Points
0
I prime the primer bulb but no gas fills the bulb
4 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 08, 2009
SOURCE: Echo SRM 1501 trimmer has minimal fire. Feels very
If this is a solid state ignition ( black box mounted right next to the fly wheel)check for rust on fly wheel and coil/ignition.Sand with light grit sand paper if nessesary. Make sure to reistall with the same gap between the two parts.note the gap at this point could also be wrong.Also check to see if the clip inside the boot where the spark plug conects is not bent and that it is conecting properly. If this is a points ignition system then its basicaly the same steps.Clean contact pionts check plug boot for good contact. Or could be bad coil.Be sure you are using a plug with the propor heat range.
Anonymous
  • Posted on Aug 01, 2009
SOURCE: How can I remove Echo 230 SRM trimmer head?
Remove the top off the string housing and remove the nut in the center.
Replace the top, as if you have finished loading string, Lock it in place as you normally do and the turn the entire housing pulling up at the same time. Spring and the white mechanism will pop out and then all you have to do is lift the string housing base off the trimmer head. Note it will take you a few tries but once it comes off you will see how easy it is to remove. I was amazed. Got my info from a sales person at Home Depot.
Anonymous
  • 10 Answers
  • Posted on Sep 05, 2009
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Anonymous
  • Posted on Feb 06, 2011
SOURCE: Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
1helpful
2answers
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 • Echo Garden
2answers
ECHO SRM 2100 GRASS TRIMMER HAS NO POWER
For all others with String trimmers, blowers and other 2 stroke style engines...
If no power on high, tends to bog, won't run once choke off, check these:
  • Fuel Filter - It's IN the Gas tank; Just replace it
  • Spark Arrestor at Muffler, it's a screen that tends to clog up and causes very restricted exhaust flow
  • Spark Plug - again just replace it
  • Carburetor, clean or install rebuild kit
  • And adjust sorta hidden High/Low carburetor adjustment screws
Take a look here...
And here:
And one more...
Aug 10, 2012 • Echo Garden
I have an echo weed wack model srm 2501. Is it possible to receive a repair manual
A general manual from Echo:
http://www.echo-usa.com/getattachment/d439e307-5aef-4017-972a-78e26efa897c/TrimmersBrushcuttersPASEdgers.pdf
Jul 17, 2011 • Garden
Echo SRM 200 series trimmer is great. I noticed though this summer once I reel in the new string, a short time of trimming later, only 1 side of the string appears. When I open up the reel, the string is...
For your machine, make sure you are using the Manufacturer's recommended trimmer line. For your model, they recommend using Echo brand .080" Cross Fire diameter line. You also need to insure that when you load the spool with the line, that it is loaded (in the right direction) so it can feed properly.
After two years of excellent service, my Echo now
Your getting a vacuum in the tank stopping the fuel getting through after a while try loosening the gas cap a tad.... may just be your problem?
Feb 03, 2010 • Garden
My echo srm-210sb will start and run, but only if I carefully find the right spot on the choke lever; like at almost full choke. Turn off the choke & engine stalls.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray withcarb.cleaner.Makesure the small screen is free of debris. (Should beable to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Dec 02, 2009 • Echo Garden
1helpful
Engine starts finem, but will not reach fill RPM.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
If you need further assistance, just let me know.
Jim
2answers
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
