Kenmore HE2 Plus Front Load Washer Logo
Anonymous Posted on Oct 20, 2017
My Kenmore 110-46462501 washing machine stopped mid-cycle
My Kenmore 110-46462501 washing machine stopped working in the middle of a cycle. All the lights on the cycle-select dial began flashing in unison and had to pull the power plug to reset it. After restarting the cycle halfway through it did the same thing again. After unplugging it again and restarting it, it now will not run the cycle at all.
Pat
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Oct 20, 2017
Pat
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
6069
Points
47
Can you hear the pump running? It might be plugged or not running
I’m happy to help further over the phone at https://www.6ya.com/expert/pat_7f6b46a4565f904d
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Nov 14, 2008
SOURCE: Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Anonymous
  • 21 Answers
  • Posted on Dec 29, 2008
SOURCE: Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Phoebe112
  • 9 Answers
  • Posted on Feb 14, 2009
SOURCE: Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Anonymous
  • 460 Answers
  • Posted on May 12, 2009
SOURCE: washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
kevin_getz
Kevin Getz
  • 1032 Answers
  • Posted on Dec 14, 2009
SOURCE: Kenmore washing machine stops mid cycle
Sounds like a dead Drain Pump.
We have a 2012 Kenmore front load washer. Model 4904. On a normal cycle it will stall out with 2 minutes left in the cycle. The only cycle that it will completely finish is on delicate.
There could be several reasons why this is happening. One possibility is that the timer or water line valve is faulty, which is causing the washer to stop mid-cycle. Another possibility is that the lid switch assembly has malfunctioned, which prevents the washer from spinning when the lid is open . Kenmore Washing Machine - Washer Stops Mid Cycle - Repair Parts ' Repair Clinic
I would recommend checking these components and their connections to see if they are functioning correctly. If you are not comfortable doing this yourself, it's best to contact a professional appliance repairman to diagnose and fix the issue
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Kenmore he3 washer stops mid cycle with no fault codes
could have a bad computer board or i've seen this happen with a bad door switch,but this is just guessing,there should be a tech sheet,remove the bottom panel and look around for the tech sheet taped to the side wall,it will tell you how to run it in diagnostics mode and how to bring up any error codes.always problems with the main ccu computer board
2answers
Washer will stop in middle of cycle
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Washing machine stops mid-cycle
F30
Was this helpful?
2helpful
2answers
1helpful
Alexander
vince
