When i turn it on it only stays on for about 3 seconds the first two ligth bulbs turns on but when the third comes on the t.v. turns off like if its protecting itself
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
See the small wire on the solonoid top of the starter body.. it might be disconnected.. if it is connected see the fuse. other option, If you have a ligth bulb connect one wire to small wire on solonoid and body ground second wire of your ligth bulb. spin the ignition key to start position if the light bulb does not light there is a cut wire from the ignition key to solonoid.
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
