Dryers Logo
Posted on Jul 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Outdoor dryer vent causing the air condidtioner problem
The outdoor vent for my dryer is depositing lint on my air conditioners(3). The service man said put a stocking over it. Do you have a better plan?
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Jul 03, 2010
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1002341
Points
8029
Did he clean out the dryer and clean out the vent line?dryers need to be cleaned out,gas dryer should be done once a year and electric dryers every two years.we come in,take the dryer apart,clean out the duct that the lint filter slides into,blow out and vac out the inside of dryer where the motor is and if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower and blow out the line,if it's clean you won't notice any lint blowing out,alot of the time when the dryer is on and heating up the vent line lint that's built up inside the vent line will blow out if the line hasn't been cleaned out,your dryer will dry the clothes better and you won't burn out any parts if the dryer is clean and not running hotter than normal from a blockage somewhere,and you don't have to worry about a dryer fire,good luck
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
tip
Why does my A/C blow little to no air, that's not cold, and how do I fix it?
Air Conditioner freeze ups cause an A/C to blow little to no air through the vents, and the air is usually warm.
There are three basic reasons for air conditioner freeze ups:
  1. Insufficient air flow
  2. Low Refrigerant charge
  3. Outdoor temperature
1) The two most common causes of insufficient air flow are dirty filters and under sized ducts. A dirty filter limits air flow which in turn allows the cooling coil’s temperature to drop below freezing. Replacing the filter, monthly, usually alleviates this problem. Under sized ducts will also cause the system to freeze because it also limits the amount of air flowing over the cooling coil. This results in lowering the coil temperature and allowing the humidity in the air to collect on the coil and freeze.
2) Low Refrigerant Charge. The refrigerant system teeters on a delicate balance. If the system is not charged correctly, the system will not function properly. This malfunction may result in the poor cooling output and/or freezing up. Only a qualified, certified service technician can properly test and charge a refrigerant system. Check your small high pressure line (should be hot) and low pressure line (should be cold, but not frozen).
3) Outdoor temperature. If temperatures are too low, the system will not operate properly, and freeze up may occur. The outdoor unit does not function well in temperatures below 60 degrees F. A special “ambient temperature” control must be installed to allow the unit to run properly in cool temperatures, or you may open your windows and save energy. If the A/C is set lower than 70 degrees F, special adapters are required to be installed.
on Jul 10, 2010 • Heating & Cooling
Why is outdoor temp stuck at 114 deg F even after replacing batteries in both units?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
If you still need help check us out online Dryer Vent Repair Dallas
I have a Honeywell thermostat. The thermostat clicks to turn the air condition on but the outdoor unit does not turn on. The fan clicks on though.
I assume you are referring to the indoor fan coming on. If the fan on the outdoor unit is coming on, and the compressor is not, you have a control problem with the outdoor unit, I recommend calling a service man. Make sure you have power to the outdoor unit. There should be a service disconnect on the outdoor unit, connect and disconnect the power, you should hear a hum when the power comes on, put your ear to the housing of the outdoor unit and you will hear the power come on when it is turned on. If no power, or hum, check your breakers in the house electrical panel, see if any are tripped. Next step call a service tech.
2answers
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
It takes two hours or more to dry clothes
Hello tront... begin by clearing the lint from the vent pipe and the outdoor end of the vent pipe. This alone will cause the dryer to take hours to dry the clothes. Joe
Ge dryer is over heating
You may have a lint clog somewhere.
Check the filter, also the outdoor vent door to see if it move freely and warm air coming out.
If not...then check the ducting going from the dryer to the outdoor vent.
If all that is ok then you may have a faulty thermostat in the dryer.
hope this helps you
Since this is free help...please take time to rate me.
Jun 27, 2011 • Dryers
My mr slim is not blowing cold air, just warm, and a message P8 is flashing
P8 means "Abnormality in Outdoor Unit"
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
