AT&T 1738 Digital Answering System with Time/Day Stamp Answering Machine Logo
Posted on Jul 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the recorded message? we do not have a manual.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • AT&T Master 102,366 Answers
  • Posted on Jun 03, 2011
AT&T Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432747
Points
622693
You can download the manual at
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=21714
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
2helpful
How to change voice message on a v-tech phone model cs6229-3 cannot change voice message-lost instructions manuel.(717)866-9262
Press Menu/Select button while phone is not in use.
Press Menuu/Select button to choose Ans System.
Press arrow up or arrow down to choose Ans System Setup, press Menu/Select button.
Press arrow up or arrow down to choose Announcement, press Menu/Select button.
You will hear the prompt "To play press 2, to record press 7. Press 7.
You will hear the prompt "Record after the tone, press 5 when you are done".
You will hear a tone, record your greeting, speaking toward the microphone. Press 5 to end recording.
Your new greeting will be played back automatically, press 5 to end replay, press 2 to start replay again, or press 7 to record again.
Minimum message length- 2 sec
Maximum message length- 90 sec
Below is a link where you can download a copy of the User manual.
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/CS6229-3-Pre_E
Lost manual dont know how to change recorded message
IF your talking about your Voicemail recording, (these steps will only work for AT&T and T-Mobile that i know of) dial into your vm once you have listened to all messages select option 4 for admin options then option 3 for greetings, then follow the system to change the vm recording
Hope This Helps! Lemme Know
William
Sep 20, 2010 • Cell Phones
I have misplaced my manual for my ntl d5100. Could
make sure you turn your answer button on after some will turn off when you change options
5helpful
How to set the answer machine for a 3410 Binatone speak easey com
Here's you manual:
http://www.binatoneonline.com/manual.aspx
Click icon under download....then save..remember where it saves it. Usually when the machine will not record messages there are only a few things that can be wrong....check the Telephone Answering Machine(TAM) section.
You might need to erase all the data and/or change to the correct mode for the phone to function properly. Obviously having the manual will help! :-)
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
1helpful
How to I record a message for answering machine
Press "MENU"
Scroll to "Answering Machine", Press "Set/Save"
Scroll to "Record Greeting", Press "Set/Save"
Following Instructions that appear on LCD screen to record message.
3helpful
2answers
1738 att answ machine-need to change message
Record Your Announcement
Before using this answering system, you
should record the announcement (up to
three minutes long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a pre-recorded
announcement: “HELLO. PLEASE LEAVE A
MESSAGE AFTER THE TONE.”
1 Press and hold a. When the
system beeps, speak toward the
microphone normally, from about nine
inches away. While you are recording,
the Message Window blinks .
To stop recording, release a.
The system automatically plays back
your announcement.
To review your announcement, press
and release a.
To erase your announcement and
return to the pre-recorded announcement,
press Dwhile your announcement is
playing.
Callers can skip the announcement by
pressing #.
Change personal recording/message
press the menu button until you get to announcement. then press rec memo button and on the prompt, record your message. when done press square stop button done
2answers
Change Answering Machine message in Lucent 1872 corded phone
I have this phone and manual. In order to record a new message follow this, 1. To record a new message 2. Pres [ANNC] 3. Choose the message location by pressing [Select] untill the appropiate mailbox is located. 4. Press [Record]. Begin speeking after the beep. 5. When finished press [Stop] 6. Repeat above to record another announcemnt GarryM
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
