Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Posted on Jul 02, 2010
I have been asked to get ic tda8375a for my sony trintron tv .I want to know whether this is available and at what [email protected]
  • imrantoheed Oct 04, 2013
    falt is no sgnal if
  • Srimanta Ray
    Srimanta Ray Jan 14, 2019
    I NEED THIS ic FOR MY SONY TRINITON
    HOW CAN I GET??
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
507
Points
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
2helpful
2answers
My sony trintron 21" bottom
RE-SOLDER VERTICAL SECTION & CHECK IT.ALSO CHECK PIN CUSHION SECTION.
Sony Trintron 36 tv won't turn on blinks 6 times
hi
low voltage overload A or B board ic 6007 defect
HI I HAVE SONY TRINTRON TV I NEED TO RESET THE TV
I already seem this on that model and it was a short diode D503 part # BY228GP.
2helpful
3answers
2answers
I want to replace my fbt
Your required FBT is available in Part Store. Check it out.
Sony 32" Triniton TV. Will not turn on.
The four blinks indicate a vertical deflection problem. I would suspect either bad connections on the vertical IC or a defective IC. This IC is a small flat IC with about 9 pins or so and should be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC.
You may also need to replace some capacitors in the circuit, but try the IC first and keep us updated.
Dan
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
