SOURCE: freeview problems
Chances are that your reception just isn't strong enough to receive the 'less-commercial' channels. Happens to us all.
Not that this is really a 'solution', but I wasn't going to post it as a 'clarification request'.
Anyway, sorry for being the bearer of bad news.
SOURCE: how do you connect bt vision to a sony bravia kdl
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
SOURCE: I have a Sony Bravia
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
SOURCE: problems with sony bravia lcd
We had this trouble with our sony bravia, had to get a repair man in to look at it and the digital tuner within the tv went cost $180.00 to have a new digit tuner put in.
