Would like to know the procedure for adjusting the low idle speed and the high operating speed
Turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000
RPM?
http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
