Put into nuetral,undo the five bolts around lower unit,take off sideplate halfway down leg casing,loosen the two bolts clamping the gear rods together,then lower unit should slide down[if driveshaft isnt stuck in the crankshaft spline].assembly is reverse,but take care putting water tube back into rubber grommet,and tighten gear rod clamp only after making sure that g/box is in nuetral,when gear lever also in nuetral,or matched together
Testimonial: "thank you so much for you help on the johnson 25hp lower unit . without your help we never could have done it. it is put back together and works great!!! keep up the great work. mamawhughes"
1995 lower clutch fork
