Started bike it stalled then nothing on key
Hi
Check the main fuse - usually located on the starter solenoid
Check condition of battery & ensure connections are good
Check wiring & connections from battery - to earth point: Check fastness
Check wiring & connections from battery + to starter solenoid and on to Ignition switch then to fuse box
Still got a problem ?
If so get a meter & check the above mentioned wiring for continuity
Check battery voltage & check for power at solenoid & at connections to / from the ignition switch
If that doesn't find the problem then try an Exorcism
Ride Safe
Bike-Doc
