Ford 1994 Explorer. After 20-30 minutes of driving in Tucson Hot Weather (104-109 degrees) the truck check engine lights goes on and shortly after it will shut down. Spark plugs will not fire up and engine turns off. For the next 15-20 minutes the enginer will turn over but does not fire up. After 20 mintues of non operation the Truck will start up fine and continue working fine. I think it might be the crank shaft position sensor, but when I run the OBD I scanner on the engine no error codes come up for the Crank Shaft sensor. What does come up is an error code for the EGR? help...
