onga pump we have a old jet pump wich is working good but for small stress cracks around bolts on the plastic pump housing ,can this be repaired ? thanksonga pump we have a old jet pump wich is working good but for small stress cracks around bolts on the plastic pump housing ,can this be repaired ? thanks
You can't post conmments that contain an email address.
What do I do if my pool/spa pump is loosing suction or prime?
Answer:
by Osko Pool n SpaPool Pump Losing Suction or Prime
If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
PUMP HOUSING LEAKS.. 3 THINGS COME TO MIND.# 1 IS THE SHAFT SEAL #2 IS THE TANK GASKET IS BAD, OR THE DREADED TANK BODY IS CRACKED. NOT UNCOMMON FOR THESE PUMPS. TAKE PUMP APART (MOTOR OFF) LET SIT AND DRY A LITTLE AND YOU WILL NEED TO LOOK CLOSE AND THE CRACKS STICK OUT BETTER WHEN SLIGHTLY DRY. IF IT IS CRACKED, THERE IS NO FIXING IT WITH GLUE. IT MUST BE REPLACED. IF IT COMES TO THAT POINT , I WOULD RECOMMEND A STA RITE DURA GLASS . 1 HP. THE SUPER PUMP YOU HAVE IS NOT THAT EFFICIENT. THEREFORE I RECOMMEND THE SR 1 HP. IT WILL SAVE YOU ON POWER ALSO , HEY YOU .. REMEMBER TO PRIME THE PUMP AFTER ANY PUMP REPAIR !!!... JAY FLORIDA
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
pool pump repair guy in longwood florida , here to save the day.. Ok what you have is a bad shaft seal (90% of the time) OR tank crack or a cracked seal plate or a bad gasket or o-ring.. look at the link and it wil help you ID your pump and take it apart. prim that pump after a repair !!! www.poolmotorrepair.com/
the cost of a shaft seal
One or more of a couple issues is at play here. First would be the seal replacement. Even if you used the correct seal if you touched the surfaces or failed to install it properly it can and will leak. Second, inspect the housing around the seal fit and the stem of the impeller for cracks. A hairline crack is enough when placed under pump operating pressure to allow a leak. Somewhere in there is your solution.
Your seal plate could be warped or check for dirt at the base of the housing when you take it apart also check the brass gromets the six bolts screw into on the main housing. If these are pulled out at all you will need to replace the housing.
I would check first to see where the leak is, make sure the pan bolts are tight & if it still leaks, it should be resealed, with new oil pan gasket set. Hope this helps, Rick
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
