Nokia 6600i Slide Cell Phone Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia 6600i slide screen not showing very well. Pictures and background not clear to see caller Id or make calls.
rajat arora
Level 2:
  • Expert 136 Answers
  • Posted on Jul 01, 2010
rajat arora
Expert
Level 2:
Answers
136
Questions
0
Helped
29092
Points
285
Display cable is lose at the contact point, place it correctly on the contact point, your problem will be solved then
2answers
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Forgot security code to my nokia 6600i slide.how to reset this code?
i Have a Nokia 6600i Slide and i forgot my password my IMEI is 355249035920374 And its Hard locked
How do you turn on a nokia 6600i slide
just try pressing the call end key or may be the on/off switch in on the top of the phone
Hi, I have a problem with incoming calls: I can phone but I can't receive calling form others...the phone doesn't ring, while the calling phone is ringing as normal. Resetting the phone can help me? How...
format the set.press *3 and call botton.by press those bottons switch on the power botton.dnt release the power botton unless u find formating on the screen.see that the battery is fully charged.ater completing the formating the phone restsarts
3helpful
How to activate the front cam of my nokia 6600i slide to take a photo?
Make a 3G video call, thats how you activate it. That is the only purpose that the front camera can be used for on series 40 nokia's.
It cannot be used as a camera for taking pictures or capturing video.
If you want a nokia that allows you to use the front camera to take low quality pictures/video then you need to buy one of nokia's smartphones.
How can I configure my phone to show caller id?
If it is nokia you will go to settings - call - caller id the you will select yes. If not nokia is still the same procedure. Thanks
2helpful
2answers
I have a Nokia e71, and everytime I call someone the caller ID on the person's phone says "private caller". How can I change this?
Telephone settings
Select Menu > Tools > Settings > Phone.
Select from the following:
• Call — Define general call settings.
Call settings
To display your phone number to the person you are
calling, select Call > Send my caller ID > Yes. To let
the network determine whether your caller ID is sent,
select Set by network.
2answers
Have got (1 new call) showing on my screen and cannot clear it
have got (1 new call) showing on my screen and cannot clear it
Caller display on my nokia3110 mobile phone
you will need to check with your provider to see if they can activate caller id for you.
for this to work both parties must have caller id active on there service
Dec 06, 2007 • Nokia 6230
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
