Movado Rondiro 605964 Wrist Watch for Women Logo
Posted on Jul 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove links on Movado Rondiro #605499 to make the bracelet smaller
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jul 01, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847017
Points
4702
Mcdevito75 here, By the time you recieve the special tool needed to reove the links you can have a small watch repair shop in your area do the job.
I need a valuation on a ladies gold movado watch. Serial number A63165
Hello there, the serial number on a Movado watch is usually unique to each watch and therefore a watch cannot be identified by that. Here is a picture of all the gold ladies Movado watches which are presently available. I have numbered them 1 - 8 accordingly.
1 and 2 are both tagged the Amorosa and are valued at $895 and $1395 respectively.
3 and 4 are both tagged the Concerto and are valued at $2495 and $1495 respectively.
5 and 6 are both tagged the Bellamoda and are valued at $1495 and $1095 respectively.
7 is the Harmony and is valued at $895
8 is the Rondiro and is valued at $1495
If your watch is not on the list above then you might want to send it to the nearest Movado authorised dealer to confirm if it is original or a knock off.
Hope this support has been helpful?
Thank you for visiting FixYa
Sep 10, 2011 • Watches
How do you take out the links on the bracelet? I want to make he brcelet smaller. I can see where there are arrows on the links that can be taken out but cannot workout how the links can be removed.
If you cannot work out how to remove a link, take it to a watch shop.
Don't be tempted to apply a large force on any of the pins as you may damage them.
1helpful
How do i get extra links for a concord veneto
Go to watchbands.com, enter your model number and bracelet size and problem solved!
How do I remove links on a Movado elliptica?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
1helpful
How do you remove a link without using any tools
You don't say much in your question ...
So ... I'm guessing ...
I'm guessing you have a watch with a expansion band that has removable links.
I'm also guessing it has a snap fastener and you have already made your band smaller through adjusting that part of the bracelet.
I'm guessing that yours is of a similar design to several I have owned and/or adjusted for others.
I'm guessing you have a paper clip in your home or office and ...
I am also guessing you never thought of a paper clip as a tool.
Straighten one leg of the paper clikp and pop out the little keeper on two of those links, reattach the loose ends for a smaller bracelet. There should be a little arrow pointing in the direction you should push the little clip/keeper.
I hope this helps you make your bracelet the size you need it to be.
Thanks for your question at FixYa.com
Jan 08, 2010 • Watches
8helpful
How to adjust a movado band
If there are screw on each side- you have to use two screwdrivers simultaneously. If not- read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together. Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!! Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
7helpful
Wirst band problem
Job done!
Shorten movado wristband
There is nothing you can do yourself as the special equipment is needed.
Find your nearest watchmaker and ask to shorten your bracelet.
Top Movado Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Movado Watch Expert? Answer questions, earn points and help others
