Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
Posted on Jul 01, 2010
Trying to pair my HTC EVO to plantronics explorer 233 Bluetooth headset
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2112
Points
40
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
  • kevinmall385 Mar 15, 2011
    thank you your advise was right on the money.
  • Kerri Lafaurie
    Kerri Lafaurie Nov 20, 2013
    Thanks so much. Thought I was out $40.
Need a pass key for my plantronics explorer 233 bluetooth
I would try 0000 if it is a brand new headset that is the universal default password for those hope i could help =]
Is the plantronics 232 headset compatible with the HTc Inspire
The Plantronics Explorer 232 is compatible with the HTC Inspire. Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. Here is a link for the pairing instructions:
Plantronics Explorer 230 Pairing Instructions
Good luck from Headsets Direct!
1helpful
2answers
My explorer isnt doing anything.. the led is solid blue and has been for hours.. it seems to be on, but not functioning. my evo wont even pick it up on its bluetooth search
The headset must be put into pairing mode. Once you make your phone discoverable, then put the Plantronics 230 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Here is a link for the pairing instructions for the 230 headset:
2answers
Please help pair my Explore 233 to a Samsung T-mobile
The default pairing code for Plantronics is 0000 (4 zeros). If you need more help, try their interactive pairing guide: http://www.plantronics.com/media/media_resources/easytopair/
3helpful
Hello
The code will most likely be "0000"
or try "1234"
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
17helpful
Plantronics explorer 233 bluetooth and blackberry 8100
On your main screen scroll down to the bluetooth icon.
click it
add device will appear
click "search for devices from here"
then get your bluetooth
hold the side button until it flashes red and blue. then release
it will find your bluetooth
scroll up and highlight it.
the passkey is "0000" when it ask for it
then click again
let the 2 pair
you should be golden
696helpful
4answers
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
