SOURCE: Lost data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
SOURCE: Cannot transfer photo from my SD card to computer
either your pc card reader or adapter for sd card is at fault here....but try this way connect your camera to pc (using usb cable)...go to my computer see the new device (camera) click on it to open ...your pix are there now copy & paste (click & drag) to your folder on the pc...hope this is helpful...feel free to rate
SOURCE: i cant delete,format and transfer the files to and from the card
What type of card you are using? If you are using an SD card, make sure that it's not locked. You may want to try using different card reader or different computer.
You may try formatting the card under the Disk Management. To do this, please follow the steps below:
1. Right-click 'My Computer' (for Win XP) or 'Computer' icon (for Vista).
2. Select 'Manage'.
3. Locate and open the 'Disk Management'.
4.Connect the card and check if the drive letter for the card will appear.
5. You may right-click on the drive letter and format it.
If you get the same problem, then probably, the card already quit working.
SOURCE: how can i retrieve all my other files on my memory card?
you will need to do DATA RECOVERY and you will need special software to do it.
you might try photorec
the card has likely been damaged
