Refrigerators Logo
Posted on Jun 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint Fridge Freezer FF175B Fridge not working?
Anonymous
Level 3:
  • Master 3,917 Answers
  • Posted on Jun 30, 2010
Anonymous
Master
Level 3:
Answers
3917
Questions
5
Helped
916224
Points
11199
Hi
Please check the link bellow and read the article therein thoroughly to diagnose the problem to your refrigerator…
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itsstoppedcompletely
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
3 Related Answers
Coolpoint
  • Posted on Jun 17, 2008
SOURCE: hotpoint ff175b fridge freezer
I had the same problem. Hotpoint told me it was the electronic card, and I waited 3 weeks for them to get one in stock. Just been fitted and made no difference, though the Hotpoint man told me it was fixed. I have just spent half an hour "shaking and whaking" various bits at the back of the fridge freezer and the compressor has finally kicked into life.
Concentrate your shaking and whacking on the black square thing to the left of the compressor.
Going to quit my job and become a freezer repair man.
mgprice
Mike Price
  • 744 Answers
  • Posted on Jul 23, 2009
SOURCE: Hotpoint ff175b fridge freezer. Freezer working
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
arikrom
911 SERVICE TODAY
  • 528 Answers
  • Posted on Jan 01, 2010
SOURCE: my hotpoint fridge freezer ff175b has started
the timer is getting bad probebly but till it is not stop working dont tuch it
2answers
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
1helpful
My Hotpoint FF175B is making a loud buzzing sound from behind the freezer thermostat panel, please help !
Sounds like a sticky relay on the board, but could be an alarm buzzer! Is the freezer working ok?
1helpful
2answers
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
6helpful
Hotpoint ff175b fridge freezer. Freezer working but fridge is not. please help
1helpful
2answers
2helpful
3answers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
2answers
Hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
