Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
How do I keep the pump flap on the basket form stcking?
  • Jacuzzi Master
  • 1,389 Answers
EASY.. REMOVE IT.. MOST CASES ITS NOT EVEN NEEDED ... FEW PUMPS EVEN HAVE IT = SO YOU DON'T NEED IT REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Posted on Jun 30, 2010
6ya staff
SOURCE:
How do i drain my washer out
remove outlet hose hold end below water level empty into basen
Apr 19, 2015 | LG Washing Machines
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
My pump isnt priming. I have put water in the area with the basket and it isnt filling up. We have replaced the seal and the tank doesnt seem to be filling back up therefore the water isnt filling up in...
Is there enough water in the pool 1/2 way up the skimmer flap to prime the lines, Are the skimmers clogged? Are all valves in their correct position? Have you checked the gasket on the top of the filter? Is the spring weak/broken, handle should have some tension, has the gasket rolled, torn or slid?
Sep 11, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward Navigator moves very very slowly. Pool Filter cartrage is clean & I have replaced the shoes, flippers, flaps & impeller bearings. Also tried different hose. Pressue on hose is about 12 to...
Make sure to keep the leaf canister and pump basket clear. Another thing to check is; make sure the screws that hold on the pods(the "flippers" on the sides) are Really tight. Those need to be cranked down pretty hard to ensure that they can move the cleaner along.
www.cpo2go.com
Aug 08, 2010 | Hayward Navigator Pool Cleaner
Error code 8 appeared and now cannot get basket
The machine did not complete its cycle, either while finishing a brewing cycle or a cleaning cycle. This is caused because the motor is not strong enough and overheated. I think it is a design problem, but there is a "work-around" solution.
First, to put basket back, look inside opening. You will see a flap at the back of the opening. This flap is down and is what is preventing insertion of basket. Take only the grounds basket. Tilt the grounds basket and insert it so the back end of basket goes under the flap. Then level out the basket. Note the flap is now inside the back end of the grounds basket. Holding the basket up and level, re-insert the drip tray and the basket holder underneath the basket. These should now slip into place.
The "work-around" solution is to let the motor cool down. Unplug the machine for at least 30 minutes, then turn unit back on, and the cycle should complete because the motor is now cool.
I notice this error 8 happens mainly when the voltage from the Hydro Utility is low. This happens during peak electricity usage hours. So, to clean your machine, do it on the week-end during the daytime either mid-morning or mid-afternoon.
Good luck
Sep 27, 2009 | Jura Capresso Coffee Makers & Espresso...
Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Apr 14, 2009 | Fellowes PS60C-2 Shredder
Shredder flap has fallen off -- company no longer makes part
Those plastic tabs are so pesky. They always break.
You can try taking some wire, perhaps an old coat hanger, and cutting 2 lengths of 4-6" each. Then attach the wire pieces in place of where the tabs were using heavy tape, which should allow enough flexibility to get the new tabs back in the holes.
If the tabs were bigger/thicker than the coat hanger wire, go to the hardware store (Lowes, Home Depot, Ace, etc.) and ask to see the metal rods. Then just pick a piece of the right thickness and they'll probably even cut it for you with their chain cutting tool.
Mar 24, 2009 | Cross Infoguard Shredder SX102M
Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
Something caught between the Tub and asket. How do I get access?
iots only 1 trick i know..taking that this is a piece of clothes..take the bottom front panel off..ane remove the tub to pump sump hose,,that will give you a 4 to 5 inch hole to work form..try and push what ever it is towards hole...onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag top load neptune washer
Have no idea why you would only get 20V at the pump when you get the full 120V in test mode. However, if you do get 120V, not 20V, then the chances are that the water level pressure switch is giving a faulty reading which tells the board that the basket is already empty.
Apr 29, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
117 people viewed this question
Top Jacuzzi Garden Experts
roeb
john h
Marvin
Marvin
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
