Samsung HLN617W 61" Rear Projection HDTV Logo
Anonymous Posted on Jun 30, 2010
Small white spots appearing on T.V. screen.
Started with just one spot now there are three spots on screen.
dick davis
Level 3:
  • Samsung Master 610 Answers
  • Posted on Jun 30, 2010
dick davis
Samsung Master
Level 3:
Answers
610
Questions
5
Helped
222098
Points
1808
The DLP chip is failing and will have to be replaced. Samsung is covering the cost of repair for this problem on SOME models. You can call 1-800-samsung to find out if your unit is covered or to find the nearest service center.
Small white spots on screen acer x1230k
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
http://www.lampdeng.com
1helpful
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
My screen is showing white spots (pixel size) How do get rid of them
On a WS-73735 the white spots usually mean a failing or damaged optical light engine.
It is a major part----Google the model number with "problems" or "light engine" etc.
3helpful
3answers
White spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
1helpful
I have a tiny white spot showing up on the screen
It's a bad pixel spot. I have a TV that has a dark spot.
Nothing you can do about it.
Three small white spots appered on the screen. about the size of a pencil eraser.?
Light Engine call Encompass Parts 1-800-638-3328 or try UED 1-800-648-6657 .you will begin to have more white spots appearing as time pasts .
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
